Hover-1 Eagle LED Headlight Replacement
  1. Hover-1 Eagle LED Headlight Replacement, LED Headlight: step 1, image 1 of 3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: step 1, image 2 of 3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: step 1, image 3 of 3
    • Remove the four screws from the bottom side of the display housing using a Phillips #2 screwdriver.
  2. Hover-1 Eagle LED Headlight Replacement: step 2, image 1 of 3 Hover-1 Eagle LED Headlight Replacement: step 2, image 2 of 3 Hover-1 Eagle LED Headlight Replacement: step 2, image 3 of 3
    • Carefully remove the top of the housing containing the display screen.
    • Remove the top of the housing slowly to avoid damaging the wires.
  3. Hover-1 Eagle LED Headlight Replacement: step 3, image 1 of 2 Hover-1 Eagle LED Headlight Replacement: step 3, image 2 of 2
    • Slide the LED light cover upwards out of the display housing
    • Be gentle when removing the LED light cover to avoid damaging the LED's connecting wires.
    • The LED circuit board should slide out with the LED light cover.
    • To reassemble, align the prongs of the LED cover with the holes in the LED circuit board.
  4. Hover-1 Eagle LED Headlight Replacement: step 4, image 1 of 3 Hover-1 Eagle LED Headlight Replacement: step 4, image 2 of 3 Hover-1 Eagle LED Headlight Replacement: step 4, image 3 of 3
    • Using a soldering iron, desolder the black and red wires from the LED circuit board.
    • To reassemble, solder the same black and red wires onto the new LED circuit board.
4 other people completed this guide.
Andrew Gaskell
1,008 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2020 Member of Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 1,074
