Hover-1 Eagle Throttle/Brake Lever Replacement
  1. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: step 1, image 1 of 3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: step 1, image 2 of 3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: step 1, image 3 of 3
    • Unscrew the scooter handle.
    • The scooter handles are left-handed or reverse threaded, so twist clockwise to remove them.
  2. Hover-1 Eagle Throttle/Brake Lever Replacement: step 2, image 1 of 3 Hover-1 Eagle Throttle/Brake Lever Replacement: step 2, image 2 of 3 Hover-1 Eagle Throttle/Brake Lever Replacement: step 2, image 3 of 3
    • Push back the fastening clips by wedging the plastic spudger between the clip and the throttle handle.
    • Insert iFixit opening picks between each fastening clip and the throttle handle to prevent re-fastening.
    • Pull the throttle lever off gently by pulling towards you.
    • The spring housed in the handle can sometimes send the lever flying. Maintain a firm grip on the throttle lever.
  3. Hover-1 Eagle Throttle/Brake Lever Replacement: step 3, image 1 of 3 Hover-1 Eagle Throttle/Brake Lever Replacement: step 3, image 2 of 3 Hover-1 Eagle Throttle/Brake Lever Replacement: step 3, image 3 of 3
    • To reassemble, insert the spring into the placement hole, housed inside the throttle handle. Insert the other end of the spring into the placement hole inside the throttle body housing.
  4. Hover-1 Eagle Throttle/Brake Lever Replacement: step 4, image 1 of 3 Hover-1 Eagle Throttle/Brake Lever Replacement: step 4, image 2 of 3 Hover-1 Eagle Throttle/Brake Lever Replacement: step 4, image 3 of 3
    • Twist the throttle lever back to its original orientation by rotating it to the left.
    • Apply pressure to the throttle handle until you hear the fastening clips take hold the of the throttle lever.
    • Make sure the throttle lever is fully inserted and flush with the display throttle body.
  5. Hover-1 Eagle Throttle/Brake Lever Replacement: step 5, image 1 of 3 Hover-1 Eagle Throttle/Brake Lever Replacement: step 5, image 2 of 3 Hover-1 Eagle Throttle/Brake Lever Replacement: step 5, image 3 of 3
    • Reattach the scooter handle.
    • Make sure to twist the handles counterclockwise to tighten.
Finish Line
4 other people completed this guide.
Andrew Gaskell
1,008 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2020 Member of Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Members
6 Guides authored
24 Comments
Great detail……….. Where can I buy the replacement part (throttle) the company hover1 isn't answering me and they don't have this part on their website. Thanks
hanjna76 - Reply
Im needed a throttle did anyone have any luck?
rodarte_amanda1992 -
Where do I buy the part where do I get it please let me know The brake lever
poorbubbaa - Reply
Necesito acelerador y no lo encuentro.
Josue Villanueva - Reply
I cant squeeze the spudger and the pick between this and the spudger broke…what the!!!
Cheri Rael - Reply
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 110
All Time: 15,648
