Hover-1 Folding E-Scooter Rear Wheel Replacement
  1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: step 1, image 1 of 2 Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: step 1, image 2 of 2
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Rear Wheel Replacement: step 2, image 1 of 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: step 2, image 2 of 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: step 2, image 3 of 3
    • Slide off the plastic side panel.
  3. Hover-1 Folding E-Scooter Rear Wheel Replacement: step 3, image 1 of 1
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Rear Wheel Replacement: step 4, image 1 of 1
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Rear Wheel Replacement: step 5, image 1 of 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: step 5, image 2 of 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: step 5, image 3 of 3
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Rear Wheel Replacement: step 6, image 1 of 1
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
Luke Imai
133 Reputation
1 Guide authored
Cal Poly, Team S15-G5, White Fall 2018 Member of Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Members
5 Guides authored
2 Comments
Where can you get replacement rubber for the front and rear wheels?
jackricotta - Reply
How about adding a rear wheel removal article for the Hover-1 Alpha folding scooter?
sfaheysd - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 67
All Time: 5,311
