Hover-1 H1 Gyroscope Sensor Assemblies Replacement
  1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Bottom Shell: step 1, image 1 of 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 2, image 1 of 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 3, image 1 of 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 3, image 2 of 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 4, image 1 of 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: step 5, image 1 of 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: step 5, image 2 of 2
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
  6. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 6, image 1 of 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 6, image 2 of 2
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  7. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 7, image 1 of 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 7, image 2 of 2
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  8. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 8, image 1 of 1
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
  9. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 9, image 1 of 3 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 9, image 2 of 3 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 9, image 3 of 3
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
  10. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 10, image 1 of 1
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  11. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 11, image 1 of 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 11, image 2 of 2
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
  12. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 12, image 1 of 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 12, image 2 of 2
  13. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: step 13, image 1 of 1
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
5 other people completed this guide.
Aaron Teh
442 Reputation
2 Guides authored
Cal Poly, Team S17-G6, White Fall 2018 Member of Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Members
7 Guides authored
One Comment
where can I get the replacement parts?
Rob Sayles - Reply
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 106
All Time: 5,098
