Hover-1 Horizon Left Balancing Sensor Replacement
  1. Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: step 1, image 1 of 2 Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: step 1, image 2 of 2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Left Balancing Sensor Replacement: step 2, image 1 of 2 Hover-1 Horizon Left Balancing Sensor Replacement: step 2, image 2 of 2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Left Balancing Sensor Replacement: step 3, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 3, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 3, image 3 of 3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: step 4, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: step 4, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: step 4, image 3 of 3
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Left Balancing Sensor Replacement: step 5, image 1 of 2 Hover-1 Horizon Left Balancing Sensor Replacement: step 5, image 2 of 2
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Left Balancing Sensor Replacement: step 6, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 6, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 6, image 3 of 3
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Left Balancing Sensor Replacement: step 7, image 1 of 2 Hover-1 Horizon Left Balancing Sensor Replacement: step 7, image 2 of 2
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Left Balancing Sensor Replacement: step 8, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 8, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 8, image 3 of 3
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Left Balancing Sensor Replacement: step 9, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 9, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement: step 9, image 3 of 3
    • Unclip the black connector by squeezing both sides and pulling them apart.
  10. Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: step 10, image 1 of 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: step 10, image 2 of 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: step 10, image 3 of 3
    • Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
    • The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
  11. Hover-1 Horizon Left Balancing Sensor Replacement: step 11, image 1 of 2 Hover-1 Horizon Left Balancing Sensor Replacement: step 11, image 2 of 2
    • Remove the sensor tab by carefully lifting it away from the hoverboard.
Jesus
85 Reputation
1 Guide authored
Cal Poly, Team S13-G6, White Fall 2018 Member of Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 39
All Time: 1,338
