Hover-1 Horizon Left Gyroscope Sensor Board Replacement
  1. Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Base Plate: step 1, image 1 of 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Base Plate: step 1, image 2 of 2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 2, image 1 of 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 2, image 2 of 2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 3, image 1 of 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 3, image 2 of 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 3, image 3 of 3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: step 4, image 1 of 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: step 4, image 2 of 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: step 4, image 3 of 3
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 5, image 1 of 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 5, image 2 of 2
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 6, image 1 of 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 6, image 2 of 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 6, image 3 of 3
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 7, image 1 of 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 7, image 2 of 2
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 8, image 1 of 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 8, image 2 of 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 8, image 3 of 3
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 9, image 1 of 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 9, image 2 of 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: step 9, image 3 of 3
    • Unclip the black connector by squeezing both sides and pulling them apart.
Casey Winans
324 Reputation
2 Guides authored
Cal Poly, Team S13-G6, White Fall 2018 Member of Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 123
All Time: 3,875
