Hover-1 Horizon Power Button Replacement
  1. Hover-1 Horizon Power Button Replacement, Base Plate: step 1, image 1 of 2 Hover-1 Horizon Power Button Replacement, Base Plate: step 1, image 2 of 2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Power Button Replacement: step 2, image 1 of 2 Hover-1 Horizon Power Button Replacement: step 2, image 2 of 2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Power Button Replacement: step 3, image 1 of 3 Hover-1 Horizon Power Button Replacement: step 3, image 2 of 3 Hover-1 Horizon Power Button Replacement: step 3, image 3 of 3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Power Button Replacement, Power Button: step 4, image 1 of 1
    • Reorient the Hover-1 Horizon so the base plate opens towards you.
  5. Hover-1 Horizon Power Button Replacement: step 5, image 1 of 3 Hover-1 Horizon Power Button Replacement: step 5, image 2 of 3 Hover-1 Horizon Power Button Replacement: step 5, image 3 of 3
    • Remove the connector by squeezing the tab and lifting up.
  6. Hover-1 Horizon Power Button Replacement: step 6, image 1 of 3 Hover-1 Horizon Power Button Replacement: step 6, image 2 of 3 Hover-1 Horizon Power Button Replacement: step 6, image 3 of 3
    • Remove the second connector by squeezing the tab and pulling up.
  7. Hover-1 Horizon Power Button Replacement: step 7, image 1 of 3 Hover-1 Horizon Power Button Replacement: step 7, image 2 of 3 Hover-1 Horizon Power Button Replacement: step 7, image 3 of 3
    • Unscrew the power button by holding the front and twisting the back nut counter-clockwise.
    • Push the power button through the base plate to remove.
    • A hot air gun may need to be used to remove the adhesive connecting the base plate to the power button.
Christina Fong
165 Reputation
1 Guide authored
Cal Poly, Team S13-G6, White Fall 2018 Member of Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 692
