Hover-1 Liberty Battery Replacement
  1. Hover-1 Liberty Battery Replacement, Bottom Cover: step 1, image 1 of 2 Hover-1 Liberty Battery Replacement, Bottom Cover: step 1, image 2 of 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Battery Replacement: step 2, image 1 of 2 Hover-1 Liberty Battery Replacement: step 2, image 2 of 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Battery Replacement: step 3, image 1 of 3 Hover-1 Liberty Battery Replacement: step 3, image 2 of 3 Hover-1 Liberty Battery Replacement: step 3, image 3 of 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Battery Replacement, Battery: step 4, image 1 of 2 Hover-1 Liberty Battery Replacement, Battery: step 4, image 2 of 2
    • Disconnect the large red and black wire from the battery by pulling apart the connector.
  5. Hover-1 Liberty Battery Replacement: step 5, image 1 of 2 Hover-1 Liberty Battery Replacement: step 5, image 2 of 2
    • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
  6. Hover-1 Liberty Battery Replacement: step 6, image 1 of 2 Hover-1 Liberty Battery Replacement: step 6, image 2 of 2
    • Remove the bracket by pulling it upwards, away from the hoverboard.
    • You will need to move some wires aside to remove the bracket successfully.
  7. Hover-1 Liberty Battery Replacement: step 7, image 1 of 3 Hover-1 Liberty Battery Replacement: step 7, image 2 of 3 Hover-1 Liberty Battery Replacement: step 7, image 3 of 3
    • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
    • The battery is held in place by adhesive. So, some force is required to remove it.
Patrick Bacon
411 Reputation
2 Guides authored
Cal Poly, Team S13-G2, White Fall 2018 Member of Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 2,535
