Hover-1 Matrix Pad Replacement
  1. Hover-1 Matrix Pad Replacement, Pad: step 1, image 1 of 2 Hover-1 Matrix Pad Replacement, Pad: step 1, image 2 of 2
    • Remove the screws on the back of the hoverboard using a Phillips #1 screwdriver.
    • Remove the back shell from the hoverboard.
  2. Hover-1 Matrix Pad Replacement: step 2, image 1 of 1
    • Remove the screws from the metal layer inside the hoverboard using a Phillips #1 screwdriver.
  3. Hover-1 Matrix Pad Replacement: step 3, image 1 of 1
    • Separate the upper shell of the hoverboard and the metal layer inside.
  4. Hover-1 Matrix Pad Replacement: step 4, image 1 of 2 Hover-1 Matrix Pad Replacement: step 4, image 2 of 2
    • Start by identifying the motherboard, which is the green pad shown in the picture.
    • Remove the screws on the corners of the motherboard with the Phillips #1 screwdriver and take it off.
    • There are cables attached to the motherboard so go ahead and unattach them.
  5. Hover-1 Matrix Pad Replacement: step 5, image 1 of 3 Hover-1 Matrix Pad Replacement: step 5, image 2 of 3 Hover-1 Matrix Pad Replacement: step 5, image 3 of 3
    • Use picture 1 as a guide and move the motherboard to the other side.
    • Identify the two black rubber buttons that are shown in the second picture.
    • Remove the two rubber buttons using the Phillips #1 screwdriver.
  6. Hover-1 Matrix Pad Replacement: step 6, image 1 of 1
    • Removing the rubber buttons in the previous step allows you to take the pad off.
    • Finally, take off the old pad and put on a new pad.
To reassemble your device, follow these instructions starting with step number 6 and finishing with step number 1.
Jici Zhuang
362 Reputation
2 Guides authored
UC Davis, Team S7-G2, Lore Fall 2018 Member of UC Davis, Team S7-G2, Lore Fall 2018
UCD-LORE-F18S7G2
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 581
