Hover-1 Maverick Battery Replacement
  1. Hover-1 Maverick Battery Replacement, Battery: step 1, image 1 of 2 Hover-1 Maverick Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Remove the shell.
  2. Hover-1 Maverick Battery Replacement: step 2, image 1 of 3 Hover-1 Maverick Battery Replacement: step 2, image 2 of 3 Hover-1 Maverick Battery Replacement: step 2, image 3 of 3
    • Remove the four 8mm Phillips #1 screws holding down the black plastic casing.
    • Lift off the black plastic retaining bracket.
  3. Hover-1 Maverick Battery Replacement: step 3, image 1 of 2 Hover-1 Maverick Battery Replacement: step 3, image 2 of 2
    • Pull the battery upward lightly to remove from the device.
    • The battery is secured to the device with adhesive tape.
Piper Feldman
409 Reputation
4 Guides authored
Cal Poly, Team S2-G2, White Winter 2020 Member of Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 Members
4 Guides authored
2 Comments
What voltage should the battery put out? Mines is 30v, charger is green at the wall but still the board won’t turn on
Barry Rogers - Reply
Where can I find that same battery i cant find one
Toad Blue - Reply
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 46
All Time: 2,967
