Hover-1 Maverick Central Bearing Replacement
  1. Hover-1 Maverick Central Bearing Replacement, Central Bearing: step 1, image 1 of 3 Hover-1 Maverick Central Bearing Replacement, Central Bearing: step 1, image 2 of 3 Hover-1 Maverick Central Bearing Replacement, Central Bearing: step 1, image 3 of 3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Remove the shell from the hoverboard. The central bearing is located in the center.
  2. Hover-1 Maverick Central Bearing Replacement: step 2, image 1 of 1
    • Unscrew the eight 16mm Phillips #1 screws holding the central bearing in place.
  3. Hover-1 Maverick Central Bearing Replacement: step 3, image 1 of 2 Hover-1 Maverick Central Bearing Replacement: step 3, image 2 of 2
    • Unplug the wires that run through the central bearing. There is a black and yellow one that attaches to the battery and a set of white ones that attach to the motherboard.
    • Run these wires out through the other end of the central bearing.
  4. Hover-1 Maverick Central Bearing Replacement: step 4, image 1 of 2 Hover-1 Maverick Central Bearing Replacement: step 4, image 2 of 2
    • One side of the bearing is easy to pop out with your hands.
    • The other side of the bearing has wiring for the LED light running under it, so it cannot be pulled out with your hands. To get leverage, carefully use the metal spudger to wedge out this other side.
  5. Hover-1 Maverick Central Bearing Replacement: step 5, image 1 of 1
    • Take the central bearing out of the board.
Piper Feldman
409 Reputation
4 Guides authored
Cal Poly, Team S2-G2, White Winter 2020 Member of Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 Members
4 Guides authored
One Comment
Where do I buy this central bearing of hover 1?
Sinan Sönmez - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 504
