Hover-1 Maverick Motherboard Replacement
  1. Hover-1 Maverick Motherboard Replacement, Motherboard: step 1, image 1 of 3 Hover-1 Maverick Motherboard Replacement, Motherboard: step 1, image 2 of 3 Hover-1 Maverick Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motherboard Replacement: step 2, image 1 of 2 Hover-1 Maverick Motherboard Replacement: step 2, image 2 of 2
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motherboard Replacement: step 3, image 1 of 2 Hover-1 Maverick Motherboard Replacement: step 3, image 2 of 2
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motherboard Replacement: step 4, image 1 of 2 Hover-1 Maverick Motherboard Replacement: step 4, image 2 of 2
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
2 other people completed this guide.
Cassandra Aarrestad
627 Reputation
4 Guides authored
Cal Poly, Team S7-G2, Paton Spring 2020 Member of Cal Poly, Team S7-G2, Paton Spring 2020
CPSU-PATON-S20S7G2
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 31
All Time: 2,365
