Hover-1 Maverick Motor Wheel Replacement
  1. Hover-1 Maverick Motor Wheel Replacement, Motherboard: step 1, image 1 of 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: step 1, image 2 of 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: step 1, image 3 of 3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motor Wheel Replacement: step 2, image 1 of 2 Hover-1 Maverick Motor Wheel Replacement: step 2, image 2 of 2
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motor Wheel Replacement: step 3, image 1 of 2 Hover-1 Maverick Motor Wheel Replacement: step 3, image 2 of 2
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motor Wheel Replacement: step 4, image 1 of 2 Hover-1 Maverick Motor Wheel Replacement: step 4, image 2 of 2
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
  5. Hover-1 Maverick Motor Wheel Replacement, Motor: step 5, image 1 of 2 Hover-1 Maverick Motor Wheel Replacement, Motor: step 5, image 2 of 2
    • After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench.
    • Remove the metal covering from over the motor.
  6. Hover-1 Maverick Motor Wheel Replacement: step 6, image 1 of 1
    • The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
Piper Feldman
409 Reputation
4 Guides authored
Cal Poly, Team S2-G2, White Winter 2020 Member of Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 484
