Hover-1 Nomad Gyroscope Sensor Boards Replacement
  1. Hover-1 Nomad Gyroscope Sensor Boards Replacement, Outer Shell: step 1, image 1 of 3 Hover-1 Nomad Gyroscope Sensor Boards Replacement, Outer Shell: step 1, image 2 of 3 Hover-1 Nomad Gyroscope Sensor Boards Replacement, Outer Shell: step 1, image 3 of 3
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 2, image 1 of 3 Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 2, image 2 of 3 Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 2, image 3 of 3
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 3, image 1 of 1
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 4, image 1 of 2 Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 4, image 2 of 2
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
  5. Hover-1 Nomad Gyroscope Sensor Boards Replacement, Gyroscope Sensor Boards: step 5, image 1 of 1
    • Cut the two zip ties around the bundle of wires with cutting pliers.
    • The zip tie is secured tightly around the wires. Be careful not to nick or cut any of the wires while removing the zip tie.
    • Do not puncture or cut the lithium-ion battery. Especially with a battery this large, the battery can catch fire or explode if damaged.
  6. Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 6, image 1 of 2 Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 6, image 2 of 2
    • Disconnect the circuit boards from the battery by pulling both battery connectors apart.
  7. Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 7, image 1 of 3 Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 7, image 2 of 3 Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 7, image 3 of 3
    • Disconnect the following wires connecting the circuit boards to the sensors and motors:
    • Disconnect the white connectors by pinching the tab and pulling up on the connectors.
    • Disconnect the black connectors by pulling the two sides apart.
    • Disconnect the green, yellow, and blue cables by pulling back the plastic shielding and pulling the ends apart.
  8. Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 8, image 1 of 1
    • Remove the four 14mm Phillips #1 screws in the corners of each circuit board by turning the screwdriver counterclockwise.
  9. Hover-1 Nomad Gyroscope Sensor Boards Replacement: step 9, image 1 of 1
    • Remove the circuit board by pulling it up and out of the hoverboard.
4 other people completed this guide.
Samuel Frazee
1,015 Reputation
7 Guides authored
Cal Poly, Team S15-G1, White Fall 2018 Member of Cal Poly, Team S15-G1, White Fall 2018
CPSU-WHITE-F18S15G1
4 Members
7 Guides authored
3 Comments
Any idea were can i buy the motherboard for this hover.thanks
visan florin mihai - Reply
Hey, do you know where I can find the gyroscope motherboard for the Nomad 1? Thanks
Angie M - Reply
Where can I buy these
Kyle noble - Reply
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 32
All Time: 2,220
