Hover-1 Rally Acceleration Lever Replacement
  1. Hover-1 Rally Acceleration Lever Replacement, Acceleration Lever: step 1, image 1 of 1
    • Remove one 4 mm Phillips #1 screw located directly above the acceleration lever.
  2. Hover-1 Rally Acceleration Lever Replacement: step 2, image 1 of 2 Hover-1 Rally Acceleration Lever Replacement: step 2, image 2 of 2
    • Turn the right handle grip counterclockwise.
    • The right handle will disconnect from the handlebar, exposing the acceleration lever.
  3. Hover-1 Rally Acceleration Lever Replacement: step 3, image 1 of 1
    • Remove four 2 mm Phillips #00 screws located on the acceleration throttle.
  4. Hover-1 Rally Acceleration Lever Replacement: step 4, image 1 of 1
    • Pull the acceleration lever off of the handle.
    • The acceleration lever sits perpendicular to the handle.
Van Schneider
112 Reputation
1 Guide authored
Cal Poly, Team S7-G2, Regan Winter 2020 Member of Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 Members
7 Guides authored
4 Comments
Where did you find the lever?
Jaimi Erwin - Reply
See comment below. Swap out your power throttle with the brake lever. Or reach out to Hover-1 for spare parts.
Chris Serio -
Thank you Mr Fix It Man. I haven't used my scooter in months and never tried to find parts. Swapped my throttle out with my brake lever and we're good to go hehe
Chris Serio - Reply
The throttle lever on my daughter’s scooter broke off and I have been unable to get through to Hover for replacement parts (both online and tried to call). Do you know of any universal levers that would work? Or where I could locate a lever? Bought this for my daughter to get to college classes and this is her first week and it broke (out of 90 day warranty, of course.)
Sharon Kolson - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 31
All Time: 2,128
