Hover-1 Rally Headlight Replacement
  1. Hover-1 Rally Headlight Replacement, Headlight: step 1, image 1 of 2 Hover-1 Rally Headlight Replacement, Headlight: step 1, image 2 of 2
    • Remove four 5 mm screws with a 5 mm hex key.
    • When reinstalling, gently tighten each screw simultaneously to apply equal pressure on both sides of the casing.
  2. Hover-1 Rally Headlight Replacement: step 2, image 1 of 1
    • Apply pressure to both ends of the headlight to remove it from the scooter.
    • Be gentle. You will feel some resistance due to the glue that is used.
  3. Hover-1 Rally Headlight Replacement: step 3, image 1 of 1
    • Once the headlight is loose from the scooter, disconnect the two wires using a soldering iron.
    • Use this soldering guide for tips on using a soldering iron.
Cami Lowrey
441 Reputation
3 Guides authored
Cal Poly, Team S7-G2, Regan Winter 2020 Member of Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 460
