Hover-1 Superstar Battery Replacement
  1. Hover-1 Superstar Battery Replacement, Bottom Case: step 1, image 1 of 3 Hover-1 Superstar Battery Replacement, Bottom Case: step 1, image 2 of 3 Hover-1 Superstar Battery Replacement, Bottom Case: step 1, image 3 of 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Battery Replacement: step 2, image 1 of 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Battery Replacement, Battery: step 3, image 1 of 2 Hover-1 Superstar Battery Replacement, Battery: step 3, image 2 of 2
    • Locate the four 14mm screws securing the battery bracket.
    • Remove the screws with a Phillips #1 screwdriver.
  4. Hover-1 Superstar Battery Replacement: step 4, image 1 of 1
    • Pull and disconnect the cable connector that is connected to the battery.
  5. Hover-1 Superstar Battery Replacement: step 5, image 1 of 1
    • Pull on the battery until it separates from the hover board. You may need to use some force.
    • Be sure the battery is disconnected before performing this step to avoid electrocution.
    • There will be a loud crack when the battery is removed. This is normal due to the adhesive on the back of the battery.
    • Pull the battery out of the hoverboard. Move wires away from the battery if necessary.
1 Guide Comment
How do u get a 25.2v battery at for my hover-1
chivitbprince Boonking - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 2,088
