Hover-1 Superstar Front Bumper LED Replacement
  1. Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: step 1, image 1 of 3 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: step 1, image 2 of 3 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: step 1, image 3 of 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Front Bumper LED Replacement: step 2, image 1 of 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Front Bumper LED Replacement, Front Bumper LED: step 3, image 1 of 1
    • Grab the wire of the connector you disconnected from the case earlier and slide the entire light out away from the case.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 297
