Hover-1 Titan Battery Replacement
  1. Hover-1 Titan Battery Replacement, Bottom Right Panel: step 1, image 1 of 2 Hover-1 Titan Battery Replacement, Bottom Right Panel: step 1, image 2 of 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Battery Replacement: step 2, image 1 of 2 Hover-1 Titan Battery Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Battery Replacement: step 3, image 1 of 3 Hover-1 Titan Battery Replacement: step 3, image 2 of 3 Hover-1 Titan Battery Replacement: step 3, image 3 of 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Battery Replacement, Battery: step 4, image 1 of 2 Hover-1 Titan Battery Replacement, Battery: step 4, image 2 of 2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Battery Replacement: step 5, image 1 of 2 Hover-1 Titan Battery Replacement: step 5, image 2 of 2
    • Remove the bundle of wires from the clip on the top of the battery.
  6. Hover-1 Titan Battery Replacement: step 6, image 1 of 2 Hover-1 Titan Battery Replacement: step 6, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the four 14 mm screws that hold the battery on the device.
  7. Hover-1 Titan Battery Replacement: step 7, image 1 of 3 Hover-1 Titan Battery Replacement: step 7, image 2 of 3 Hover-1 Titan Battery Replacement: step 7, image 3 of 3
    • Remove the battery out of the hoverboard by lifting the battery then sliding it out from under the wires.
Jessica Ouyang
619 Reputation
4 Guides authored
Cal Poly, Team S15-G4, White Fall 2018 Member of Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 2,072
