Hover-1 Titan Power Button Replacement
  1. Hover-1 Titan Power Button Replacement, Bottom Right Panel: step 1, image 1 of 2 Hover-1 Titan Power Button Replacement, Bottom Right Panel: step 1, image 2 of 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Power Button Replacement: step 2, image 1 of 2 Hover-1 Titan Power Button Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Power Button Replacement: step 3, image 1 of 3 Hover-1 Titan Power Button Replacement: step 3, image 2 of 3 Hover-1 Titan Power Button Replacement: step 3, image 3 of 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Power Button Replacement, Power Button: step 4, image 1 of 2 Hover-1 Titan Power Button Replacement, Power Button: step 4, image 2 of 2
    • Disconnect the battery by holding the yellow connectors and pulling apart.
  5. Hover-1 Titan Power Button Replacement: step 5, image 1 of 3 Hover-1 Titan Power Button Replacement: step 5, image 2 of 3 Hover-1 Titan Power Button Replacement: step 5, image 3 of 3
    • Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board.
    • You can also unplug the light connector to free up your work space.
  6. Hover-1 Titan Power Button Replacement: step 6, image 1 of 2 Hover-1 Titan Power Button Replacement: step 6, image 2 of 2
    • Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
  7. Hover-1 Titan Power Button Replacement: step 7, image 1 of 3 Hover-1 Titan Power Button Replacement: step 7, image 2 of 3 Hover-1 Titan Power Button Replacement: step 7, image 3 of 3
    • Pull the power button out of the panel.
    • Replace the power button.
Alexander Pham
221 Reputation
1 Guide authored
Cal Poly, Team S15-G4, White Fall 2018 Member of Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 730
