Hover-1 Titan Right Gyroscope Replacement
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: step 1, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: step 1, image 2 of 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Right Gyroscope Replacement: step 2, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Right Gyroscope Replacement: step 3, image 1 of 3 Hover-1 Titan Right Gyroscope Replacement: step 3, image 2 of 3 Hover-1 Titan Right Gyroscope Replacement: step 3, image 3 of 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: step 4, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: step 4, image 2 of 2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Right Gyroscope Replacement: step 5, image 1 of 3 Hover-1 Titan Right Gyroscope Replacement: step 5, image 2 of 3 Hover-1 Titan Right Gyroscope Replacement: step 5, image 3 of 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Right Gyroscope Replacement: step 6, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement: step 6, image 2 of 2
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Right Gyroscope Replacement: step 7, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement: step 7, image 2 of 2
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  8. Hover-1 Titan Right Gyroscope Replacement: step 8, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement: step 8, image 2 of 2
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Right Gyroscope Replacement: step 9, image 1 of 2 Hover-1 Titan Right Gyroscope Replacement: step 9, image 2 of 2
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Hover-1 Titan Right Gyroscope Replacement: step 10, image 1 of 1
    • Cut the cable tie and unplug the remaining wires.
2 other people completed this guide.
Jessica Ouyang
619 Reputation
4 Guides authored
Cal Poly, Team S15-G4, White Fall 2018 Member of Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Members
10 Guides authored
One Comment
Where can I get the circuit boards for the left and right ?
jfsucher - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 32
All Time: 1,150
