Hover-1 Titan Wheel and Motor Replacement
  1. Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: step 1, image 1 of 2 Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: step 1, image 2 of 2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Wheel and Motor Replacement: step 2, image 1 of 2 Hover-1 Titan Wheel and Motor Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Wheel and Motor Replacement: step 3, image 1 of 3 Hover-1 Titan Wheel and Motor Replacement: step 3, image 2 of 3 Hover-1 Titan Wheel and Motor Replacement: step 3, image 3 of 3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: step 4, image 1 of 2 Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: step 4, image 2 of 2
    • Unplug the battery by pulling apart the yellow connectors.
  5. Hover-1 Titan Wheel and Motor Replacement: step 5, image 1 of 2 Hover-1 Titan Wheel and Motor Replacement: step 5, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
  6. Hover-1 Titan Wheel and Motor Replacement: step 6, image 1 of 3 Hover-1 Titan Wheel and Motor Replacement: step 6, image 2 of 3 Hover-1 Titan Wheel and Motor Replacement: step 6, image 3 of 3
    • Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
  7. Hover-1 Titan Wheel and Motor Replacement: step 7, image 1 of 2 Hover-1 Titan Wheel and Motor Replacement: step 7, image 2 of 2
    • Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
  8. Hover-1 Titan Wheel and Motor Replacement: step 8, image 1 of 3 Hover-1 Titan Wheel and Motor Replacement: step 8, image 2 of 3 Hover-1 Titan Wheel and Motor Replacement: step 8, image 3 of 3
    • Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
  9. Hover-1 Titan Wheel and Motor Replacement: step 9, image 1 of 2 Hover-1 Titan Wheel and Motor Replacement: step 9, image 2 of 2
    • Unplug the green wires by gripping the wire close to the connectors and pulling apart.
  10. Hover-1 Titan Wheel and Motor Replacement: step 10, image 1 of 3 Hover-1 Titan Wheel and Motor Replacement: step 10, image 2 of 3 Hover-1 Titan Wheel and Motor Replacement: step 10, image 3 of 3
    • Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
  11. Hover-1 Titan Wheel and Motor Replacement: step 11, image 1 of 2 Hover-1 Titan Wheel and Motor Replacement: step 11, image 2 of 2
    • Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
  12. Hover-1 Titan Wheel and Motor Replacement: step 12, image 1 of 3 Hover-1 Titan Wheel and Motor Replacement: step 12, image 2 of 3 Hover-1 Titan Wheel and Motor Replacement: step 12, image 3 of 3
    • Unplug the rainbow connector by squeezing the clips and pulling apart.
  13. Hover-1 Titan Wheel and Motor Replacement: step 13, image 1 of 2 Hover-1 Titan Wheel and Motor Replacement: step 13, image 2 of 2
    • Use scissors to cut the zip tie around the group of wires.
  14. Hover-1 Titan Wheel and Motor Replacement: step 14, image 1 of 3 Hover-1 Titan Wheel and Motor Replacement: step 14, image 2 of 3 Hover-1 Titan Wheel and Motor Replacement: step 14, image 3 of 3
    • Unplug the white wire connector by squeezing the clips and pulling apart.
  15. Hover-1 Titan Wheel and Motor Replacement: step 15, image 1 of 2 Hover-1 Titan Wheel and Motor Replacement: step 15, image 2 of 2
    • Use an impact driver with a hex 6 bit to loosen the four 20 mm hex 6 bolts.
    • Wear safety glasses while using the impact driver.
  16. Hover-1 Titan Wheel and Motor Replacement: step 16, image 1 of 3 Hover-1 Titan Wheel and Motor Replacement: step 16, image 2 of 3 Hover-1 Titan Wheel and Motor Replacement: step 16, image 3 of 3
    • Pull out the loosened screws with your hands and remove the metal plate.
  17. Hover-1 Titan Wheel and Motor Replacement: step 17, image 1 of 2 Hover-1 Titan Wheel and Motor Replacement: step 17, image 2 of 2
    • Lift the wheel and motor shaft up and out of the board.
    • The motor shaft is located within the wheel.
3 other people completed this guide.
Emma Huun
312 Reputation
1 Guide authored
Cal Poly, Team S15-G4, White Fall 2018 Member of Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 43
All Time: 1,763
