Hover-1 Ultra Battery Replacement
  1. Hover-1 Ultra Battery Replacement, Battery: step 1, image 1 of 3 Hover-1 Ultra Battery Replacement, Battery: step 1, image 2 of 3 Hover-1 Ultra Battery Replacement, Battery: step 1, image 3 of 3
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Hover-1 Ultra Battery Replacement: step 2, image 1 of 3 Hover-1 Ultra Battery Replacement: step 2, image 2 of 3 Hover-1 Ultra Battery Replacement: step 2, image 3 of 3
    • Remove the 4 screws around the battery on the case using the Phillips #1 screwdriver.
    • Remove the case that houses the battery.
  3. Hover-1 Ultra Battery Replacement: step 3, image 1 of 3 Hover-1 Ultra Battery Replacement: step 3, image 2 of 3 Hover-1 Ultra Battery Replacement: step 3, image 3 of 3
    • Pinch and pull apart the connecting black and yellow cable.
    • Remove the battery from the hoverboard.
To reassemble your device, follow the instructions in step 1 in reverse order.
Camron Clifton
409 Reputation
3 Guides authored
UC Davis, Team S7-G5, Lore Fall 2018 Member of UC Davis, Team S7-G5, Lore Fall 2018
UCD-LORE-F18S7G5
3 Members
3 Guides authored
One Comment
Merci pour tous ces conseils précieux, j’ai pu réparer ma batterie de Hoverboard : https://hover-store.fr/batterie-hoverboa...
willfrite71 - Reply
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 41
All Time: 7,879
