Hover-1 XLS Battery Replacement
  1. Hover-1 XLS Battery Replacement, Battery: step 1, image 1 of 3 Hover-1 XLS Battery Replacement, Battery: step 1, image 2 of 3 Hover-1 XLS Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
    • There are four screws that need to remove. Two on one side and the two on the opposite side.
  2. Hover-1 XLS Battery Replacement: step 2, image 1 of 3 Hover-1 XLS Battery Replacement: step 2, image 2 of 3 Hover-1 XLS Battery Replacement: step 2, image 3 of 3
    • Remove the adhesive holding the wires tightly.
    • You can use a sharp object to score the adhesive before pulling.
    • Pull on both sides of the wire connections.
3 other people completed this guide.
Jonathan Hidalgo
632 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2019 Member of Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Members
7 Guides authored
16 Guide Comments
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David Schultze - Reply
David did you happen to find one? Please let me know I've been looking for one
Michael Hawk -
If anyone find a 1:1 replacement battery for this, or at the very least a wiring diagram, please post it as it's near impossible to find anything on this thing in 2022.
GutZ Era - Reply
So the yellow and a red are for the ignition and the other red and black ig is a standard ground and positive with the white being I think the temperature sensore wire. Hope this helps also trying to find a replacement and may try wiring one up.
Batman and King -
Hi, where can you find the battery replacement? I have my scooter and the battery needs to be replaced.
Mary - Reply
Past 24 Hours: 8
Past 7 Days: 77
Past 30 Days: 207
All Time: 12,812
