Hover-1 XLS Front Wheel Replacement
  1. Hover-1 XLS Front Wheel Replacement, Front Brake: step 1, image 1 of 3 Hover-1 XLS Front Wheel Replacement, Front Brake: step 1, image 2 of 3 Hover-1 XLS Front Wheel Replacement, Front Brake: step 1, image 3 of 3
    • Remove the two, 23 mm Hex #5 screws holding the brake to the bike.
    • Slide the brake mechanism off and turn it upside down to reveal the screw holding the brake wire.
  2. Hover-1 XLS Front Wheel Replacement: step 2, image 1 of 1
    • Remove the one, 14 mm Hex #4 screw pushing down the brake wire to the brake mechanism on the bottom.
  3. Hover-1 XLS Front Wheel Replacement: step 3, image 1 of 2 Hover-1 XLS Front Wheel Replacement: step 3, image 2 of 2
    • Remove the side screw holding the brake wire and mechanism together with your hands.
    • Slide the brake mechanism off from the brake wire.
  4. Hover-1 XLS Front Wheel Replacement, Front Wheel: step 4, image 1 of 2 Hover-1 XLS Front Wheel Replacement, Front Wheel: step 4, image 2 of 2
    • Remove the two, 16 mm Hex #4 screws on both of the hub caps in the front wheel.
    • There are two hub caps on the front wheel. Make sure to remove two screws for both hub caps.
  5. Hover-1 XLS Front Wheel Replacement: step 5, image 1 of 2 Hover-1 XLS Front Wheel Replacement: step 5, image 2 of 2
    • Using an adjustable spanner wrench, rotate the 165 mm bolt counter-clockwise to remove.
  6. Hover-1 XLS Front Wheel Replacement: step 6, image 1 of 3 Hover-1 XLS Front Wheel Replacement: step 6, image 2 of 3 Hover-1 XLS Front Wheel Replacement: step 6, image 3 of 3
    • After removing the first bolt, the second bolt located on the other side of the wheel will be able to be take off by hand.
    • Pull the wheel and bike in opposite directions to remove the wheel.
2 other people completed this guide.
Jonathan Hidalgo
632 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2019 Member of Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Members
7 Guides authored
1 Guide Comment
How do I get in touch with customer service for parts?
tried filling out the form on computer and phone as well tablet and it says error.
fox_Jayson@yahoo.com
please reach out
petrasherbin - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,604
