Hover-1 XLS Ignition Replacement
  1. Hover-1 XLS Ignition Replacement, Ignition: step 1, image 1 of 1
    • Remove the six 16mm #3 Hex head screws located on the front panel.
    • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
  2. Hover-1 XLS Ignition Replacement: step 2, image 1 of 3 Hover-1 XLS Ignition Replacement: step 2, image 2 of 3 Hover-1 XLS Ignition Replacement: step 2, image 3 of 3
    • Grab the front panel and gently lift it up to the side.
    • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
  3. Hover-1 XLS Ignition Replacement: step 3, image 1 of 1
    • Remove the two, 19 mm Phillips #2 screws holding the ignition.
    • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
Jonathan Hidalgo
632 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2019 Member of Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 1,339
