How To Clean Nikon Coolpix S30 Lens
  1. How To Clean Nikon Coolpix S30 Lens, Batteries: step 1, image 1 of 2 How To Clean Nikon Coolpix S30 Lens, Batteries: step 1, image 2 of 2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
  2. How To Clean Nikon Coolpix S30 Lens: step 2, image 1 of 2 How To Clean Nikon Coolpix S30 Lens: step 2, image 2 of 2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
  3. How To Clean Nikon Coolpix S30 Lens: step 3, image 1 of 1
    • Remove the batteries by gently tipping the camera.
  4. How To Clean Nikon Coolpix S30 Lens, How To Clean Nikon Coolpix S30 Lens: step 4, image 1 of 1
    • Remove the four screws the hold the back of the case to the rest of the camera.
  5. How To Clean Nikon Coolpix S30 Lens: step 5, image 1 of 1
    • Remove the left screw from the bottom of the camera first. This can be done using the same T5 tip.
    • Unscrew the screw on the right using a different attachment: PH000 (it is a small Phillip's head)
  6. How To Clean Nikon Coolpix S30 Lens: step 6, image 1 of 1
    • Remove back case from the rest of the camera carefully.
  7. How To Clean Nikon Coolpix S30 Lens: step 7, image 1 of 1
    • Remove the three screws the secure the motherboard to the front case.
  8. How To Clean Nikon Coolpix S30 Lens: step 8, image 1 of 2 How To Clean Nikon Coolpix S30 Lens: step 8, image 2 of 2
    • Remove the motherboard from the front case.
    • Leave the red and black wire attached but lay the piece in front of the case.
  9. How To Clean Nikon Coolpix S30 Lens: step 9, image 1 of 2 How To Clean Nikon Coolpix S30 Lens: step 9, image 2 of 2
    • Wipe the lens and the clear plastic on the front case to remove debris.
Courtney Weida
167 Reputation
1 Guide authored
Penn State, Team 2-4, Kaschak Winter 2015 Member of Penn State, Team 2-4, Kaschak Winter 2015
PSU-KASCHAK-W15S2G4
4 Members
5 Guides authored
One Comment
The first three steps are redundant because you already included the prerequisite guide for removal of the batteries.
Dylan Keiter - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,651
