How To Fix A Paper Towel Dispenser
  1. How To Fix A Paper Towel Dispenser, How To Fix A Paper Towel Dispenser: step 1, image 1 of 2 How To Fix A Paper Towel Dispenser, How To Fix A Paper Towel Dispenser: step 1, image 2 of 2
    • Open the paper-towel dispenser's cover using your Philips head screwdriver and turn it counter-clockwise.
    • Some paper-towel dispensers require a key to unlock them. The lock is generally located on the top of the paper-towel dispenser.
  2. How To Fix A Paper Towel Dispenser: step 2, image 1 of 1
    • Look for jams. Check every space inside the paper-towel dispenser for wads of paper towels. Remove any stray bits of paper towel that you find.
  3. How To Fix A Paper Towel Dispenser: step 3, image 1 of 1
    • Tear off the paper towels just above the rollers.
    • Remove the roll of paper towels. Pull the lever of the paper-towel dispenser a few times to dislodge any remaining paper towels.
  4. How To Fix A Paper Towel Dispenser: step 4, image 1 of 3 How To Fix A Paper Towel Dispenser: step 4, image 2 of 3 How To Fix A Paper Towel Dispenser: step 4, image 3 of 3
    • Replace the roll of paper towels. Make sure the roll is coming over the top towards you. Sometimes the paper towels will still come out of the dispenser if the roll is backward, but will tear off inside the dispenser and cause jams.
    • Push holsters outwards when attempting to put a new roll in.
  5. How To Fix A Paper Towel Dispenser: step 5, image 1 of 3 How To Fix A Paper Towel Dispenser: step 5, image 2 of 3 How To Fix A Paper Towel Dispenser: step 5, image 3 of 3
    • Feed the paper towels through the rollers. Pull the paper-towel dispenser's lever three or four times to make sure the paper is completely fed through.
    • Don't get your fingers caught!
  6. How To Fix A Paper Towel Dispenser: step 6, image 1 of 1
    • Close the paper-towel dispenser's cover. Turn tool clockwise to lock. If there is a key, lock the paper-towel dispenser.
To repair your device, follow these instructions in order.
Jeevan Vase
138 Reputation
1 Guide authored
Cal Poly, Team 24-5, Green Winter 2015 Member of Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 Members
4 Guides authored
5 Guide Comments
What to do if the screw on the top rotates freely and does not open the dispenser? How to open the dispenser then?
sheinsalu - Reply
same problem!!! how do you open it if just keep turning?
Nena Keller - Reply
Use a flat head and go deeper
Deborah Sharkey - Reply
What if your dispenser is old ? Can the springs be replaced?
Julie Newton - Reply
The paper towel dispenser only dispenses a 4” sheet of paper no matter what setting size it is on. What can I do to increase the length of the towel?
greg theus - Reply
Past 24 Hours: 10
Past 7 Days: 42
Past 30 Days: 138
All Time: 60,309
