How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan
  1. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan, How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: step 1, image 1 of 1
    • remove the three Phillips screws under the fan closest to the video ports of the card
  2. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: step 2, image 1 of 1
    • Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
  3. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: step 3, image 1 of 1
    • Reassemble and re-install the card into your computer. It should stop the vibration.
8 other people completed this guide.
Matthew Johnson
392 Reputation
1 Guide authored
One Comment
Can you post a picture showing how its fit in the fins?
Gustavo Horta - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 8,405
