How To Fix a Broken Lipstick
  1. How To Fix a Broken Lipstick, How To Fix a Broken Lipstick: step 1, image 1 of 2 How To Fix a Broken Lipstick, How To Fix a Broken Lipstick: step 1, image 2 of 2
    • Prepare a clean working space.
    • Use a gloved hand and separate the broken off piece of the lipstick from the rest of the tube (only if it is not a clean break).
  2. How To Fix a Broken Lipstick: step 2, image 1 of 2 How To Fix a Broken Lipstick: step 2, image 2 of 2
    • Twist the base so that the lipstick is fully visible.
  3. How To Fix a Broken Lipstick: step 3, image 1 of 2 How To Fix a Broken Lipstick: step 3, image 2 of 2
    • Use the toothpick to clean and level both ends of the broken lipstick.
  4. How To Fix a Broken Lipstick: step 4, image 1 of 2 How To Fix a Broken Lipstick: step 4, image 2 of 2
    • Hold a flame over both ends of the lipstick for 2 seconds, or until a top layer is melted.
    • Use caution when working with an open flame and always be aware of your surroundings.
  5. How To Fix a Broken Lipstick: step 5, image 1 of 1
    • Press the ends of the broken pieces back together.
  6. How To Fix a Broken Lipstick: step 6, image 1 of 1
    • Using a flame, melt the pieces together to form a bond.
  7. How To Fix a Broken Lipstick: step 7, image 1 of 1
    • Using a toothpick, smooth out the attachment site.
  8. How To Fix a Broken Lipstick: step 8, image 1 of 1
    • Wait 1 hour for lipstick to set before application.
In order to save time, you can place tube in the fridge for faster results.
Graciana Wood
153 Reputation
1 Guide authored
Texas Tech, Team 22-6, Rauch Spring 2016 Member of Texas Tech, Team 22-6, Rauch Spring 2016
TTU-RAUCH-S16S22G6
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 37
All Time: 2,253
