How To Fix a Jammed Box Cutter
  1. How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: step 1, image 1 of 3 How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: step 1, image 2 of 3 How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: step 1, image 3 of 3
    • Using a Phillips head screwdriver, unscrew the screw on the box cutter.
    • Remove the top part of the box cutter.
  2. How To Fix a Jammed Box Cutter: step 2, image 1 of 3 How To Fix a Jammed Box Cutter: step 2, image 2 of 3 How To Fix a Jammed Box Cutter: step 2, image 3 of 3
    • Caution: Sharp Object Involved
    • Pick up the blade.
    • Separate the blade from the trigger.
  3. How To Fix a Jammed Box Cutter: step 3, image 1 of 3 How To Fix a Jammed Box Cutter: step 3, image 2 of 3 How To Fix a Jammed Box Cutter: step 3, image 3 of 3
    • Look for the sliding bar and circle which will be located towards the end of the box cutter.
    • Place the trigger aligning with the sliding bar and the circle in the middle of the box cutter.
    • Apply pressure with your finger onto the magnetic part of the trigger to secure placement.
  4. How To Fix a Jammed Box Cutter: step 4, image 1 of 2 How To Fix a Jammed Box Cutter: step 4, image 2 of 2
    • Carefully pick up the blade and identify the left hook of the blade and identify the hook of the trigger.
    • Align the hook from the blade on top of the trigger hook.
  5. How To Fix a Jammed Box Cutter: step 5, image 1 of 2 How To Fix a Jammed Box Cutter: step 5, image 2 of 2
    • Place the box cutter back together.
  6. How To Fix a Jammed Box Cutter: step 6, image 1 of 2 How To Fix a Jammed Box Cutter: step 6, image 2 of 2
    • Hand tightly screw the screw back into the box cutter.
    • Finish off screwing the screw into the box cutter with the screw driver.
Yailene
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 33
Past 30 Days: 164
All Time: 2,429
