How To Grow An Avocado Tree
  1. How To Grow An Avocado Tree, Clean the pit: step 1, image 1 of 1
    • After removing carefully the pit from the avocado wash it gently with warm water to remove all the flesh.
    • Be careful not to remove the brown skin on the pit – that is the seed cover.
    • Avoid using soap, just use warm water and your hands.
  2. How To Grow An Avocado Tree, Locate which end is "up" and which is "down": step 2, image 1 of 1
    • All avocado pits have a ‘bottom’ (from where the roots will grow), and a ‘top’ (from which the sprout will grow). The slightly pointier end is the top, and the flat end is the bottom.
  3. How To Grow An Avocado Tree, Insert the toothpicks: step 3, image 1 of 2 How To Grow An Avocado Tree, Insert the toothpicks: step 3, image 2 of 2
    • Holding the pit "narrow" (pointed) side up, stick three toothpicks into the middle section at even intervals, just enough to give a firm hold. This will allow you to balance the pit on the inside of a cup, without completely inserting it into the cup.
    • The pit should sit in about 1 inch (2-3 cm) of water, so keep this in mind when inserting your toothpicks.
    • Don't insert the toothpicks to deep into the pit, this could damage it and it wouldn't grow anymore.
    • The shown avocado pit on the pictures hasn't the perfect shape with a pointier side.
  4. How To Grow An Avocado Tree, Fill a glass/jar with water: step 4, image 1 of 2 How To Grow An Avocado Tree, Fill a glass/jar with water: step 4, image 2 of 2
    • Add water to a small, slender glass until it reaches the top rim.
    • Your glass's opening should be wide enough to accommodate the full width of the avocado pit easily; however, make sure that it is not too wide, otherwise the toothpicks will not be able to reach and the pit will fall in.
  5. How To Grow An Avocado Tree, Place your avocado pit on the top rim of the glass: step 5, image 1 of 3 How To Grow An Avocado Tree, Place your avocado pit on the top rim of the glass: step 5, image 2 of 3 How To Grow An Avocado Tree, Place your avocado pit on the top rim of the glass: step 5, image 3 of 3
    • The toothpicks should sit on the rim of the glass.
    • Make sure the pointed end is up and the rounded end is in the water, otherwise your avocado will not grow.
    • The bottom half of the avocado should always be in water.
  6. How To Grow An Avocado Tree, Wait for your avocado pit sprout: step 6, image 1 of 1
    • Place the glass with your avocado pit in a warm place with plenty of light.
    • Change the water every 5-7 days with fresh water.
    • And now you have to be patient. It takes up to 8 weeks until your avocado pit sprouts!
    • Don't forget to fill up the water from time to time.
Stay tuned to see our grown avocado tree in a few weeks! The next technique will show how to plant the avocado tree into a pot with soil.
14 other people completed this guide.
Sarah Thalacker
935 Reputation
1 Guide authored
iFixit EU Team Member of iFixit EU Team
Staff
37 Members
1,217 Guides authored
1 Guide Comment
Noyau à inverser
P. Bu - Reply
Past 24 Hours: 7
Past 7 Days: 52
Past 30 Days: 193
All Time: 9,976
