How To Open A Desktop Hard Drive
  1. How To Open A Desktop Hard Drive, Remove The Front Screws: step 1, image 1 of 2 How To Open A Desktop Hard Drive, Remove The Front Screws: step 1, image 2 of 2
    • Use a size 8 Torx screwdriver to remove the front screws. The location and amount may vary depending on your drive, but they are very easy to locate.
    Ask FixBot
  2. How To Open A Desktop Hard Drive, Removing The Hidden Screws: step 2, image 1 of 2 How To Open A Desktop Hard Drive, Removing The Hidden Screws: step 2, image 2 of 2
    • There may be a screw hidden under the front sticker, so make sure to peel it off and check before you open it up. Use a spudger to peel off any material in the way of the screw
    • Please check under the sticker before you open up your disk drive. I didn't, and went full brute-force on the hard drive cover. Whoops!
    Ask FixBot
  3. How To Open A Desktop Hard Drive: step 3, image 1 of 2 How To Open A Desktop Hard Drive: step 3, image 2 of 2
    • Slide a spudger around the front cover to remove any adhesive or rubber insulation before opening.
    Ask FixBot
  4. How To Open A Desktop Hard Drive: step 4, image 1 of 1
    • Gently remove the cover.
    • Do NOT do what I did, please.
    Ask FixBot
  5. How To Open A Desktop Hard Drive: step 5, image 1 of 1
    • There you have it! Now you have a fully-opened hard drive. Whether you want to make a pretty cool (and large) paperweight or perma-delete your data, you can now do so.
    Ask FixBot
This is not a reversible process. I am not responsible for any damage done to you or your hard drive while opening it.
12 other people completed this guide.
gamer_Kat
451 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 38
Past 30 Days: 114
All Time: 2,363
