How To Patch A Hole In The Wall
  1. How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: step 1, image 1 of 3 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: step 1, image 2 of 3 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: step 1, image 3 of 3
    • Sand down the hole and the area surrounding. This is in order to get paint off the wall.
  2. How To Patch A Hole In The Wall: step 2, image 1 of 2 How To Patch A Hole In The Wall: step 2, image 2 of 2
    • Use the rag and the toothbrush to clean off any excess rubble near the hole.
  3. How To Patch A Hole In The Wall: step 3, image 1 of 1
    • Follow the directions on the spackle box to prepare the spackle for application.
    • Although all spackle brands are different, spackle should have a consistency similar to toothpaste when mixed with water.
  4. How To Patch A Hole In The Wall: step 4, image 1 of 3 How To Patch A Hole In The Wall: step 4, image 2 of 3 How To Patch A Hole In The Wall: step 4, image 3 of 3
    • Take the spackle mix and apply it to the hole.
    • Make sure to layer the spackle evenly and remove excess spackle.
  5. How To Patch A Hole In The Wall: step 5, image 1 of 1
    • Wait 30-45 minutes for the spackle patch to dry.
    • Wait time may vary depending on the depth of the hole and spackle mix used.
  6. How To Patch A Hole In The Wall: step 6, image 1 of 1
    • Make sure the spackle is dry.
    • Sand the spackle until it is smooth and flush with the wall.
Now your wall should be looking as good as new!
3 other people completed this guide.
Joseph Garcia
293 Reputation
1 Guide authored
Cal Poly, Team 17-2, Green Fall 2015 Member of Cal Poly, Team 17-2, Green Fall 2015
CPSU-GREEN-F15S17G2
4 Members
8 Guides authored
One Comment
I suggest using a sanding sponge or block in step 6
Dennis - Reply
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 56
All Time: 1,574
