How To Re-String A Hoodie
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. How To Re-String A Hoodie, How To Re-String A Hoodie: step 1, image 1 of 2 How To Re-String A Hoodie, How To Re-String A Hoodie: step 1, image 2 of 2
    • Uncoil the wire coat hanger into a straight line.
  2. How To Re-String A Hoodie: step 2, image 1 of 3 How To Re-String A Hoodie: step 2, image 2 of 3 How To Re-String A Hoodie: step 2, image 3 of 3
    • Tape the end of the uncoiled coat hanger to one end of your sweatshirt string.
    • Make sure the clothes hanger is securely taped to ensure that the string doesn't detach during the re-stringing process.
    • When taping, make sure no adhesive is felt over the outside of the apparatus. This will make the re-stringing process easier because the tape won't be sticking to the sweatshirt.
  3. How To Re-String A Hoodie: step 3, image 1 of 1
    • Insert the wire and string apparatus into the left opening of the hoodie.
  4. How To Re-String A Hoodie: step 4, image 1 of 1
    • Feed the wire through the hoodie until it reaches the top of the hood.
  5. How To Re-String A Hoodie: step 5, image 1 of 2 How To Re-String A Hoodie: step 5, image 2 of 2
    • Curve the wire to the right so that the wire can follow the curve of the hood.
  6. How To Re-String A Hoodie: step 6, image 1 of 2 How To Re-String A Hoodie: step 6, image 2 of 2
    • Continue feeding the wire through the hood towards the other opening of the hoodie.
    • Pull the wire and string out of the opening.
  7. How To Re-String A Hoodie: step 7, image 1 of 2 How To Re-String A Hoodie: step 7, image 2 of 2
    • Remove the tape from the end of the wire and string.
  8. How To Re-String A Hoodie: step 8, image 1 of 2 How To Re-String A Hoodie: step 8, image 2 of 2
    • Remove the wire from the hoodie by pushing the left end of the wire through the hoodie, while pulling the right end out.
  9. How To Re-String A Hoodie: step 9, image 1 of 1
    • Tie each end of the string in a knot to prevent the string from coming out of the hoodie.
Congratulations on restringing your hoodie!
4 other people completed this guide.
Ashley
267 Reputation
1 Guide authored
Cal Poly, Team 23-1, Green Winter 2015 Member of Cal Poly, Team 23-1, Green Winter 2015
CPSU-GREEN-W15S23G1
4 Members
4 Guides authored
One Comment
my apple iphone 4 is disabled connect to itunes
Ali Hemmati - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 272
