How To Repair A Solenoid Coil
  1. How To Repair A Solenoid Coil, Solenoid coil is short circuit or open circuit: step 1, image 1 of 1
    • Test the solenoid with a multi-meter, if the resistance is close to zero or infinity, it means that solenoid is either open circuit or broken circuit.
    • If open circuit or broken circuit happens, you need to change a new solenoid coil.
  2. How To Repair A Solenoid Coil, Problems with the plug: step 2, image 1 of 1
    • If there is a plug on the solenoid valve, you may need to check the metal spring clip inside the socket.
    • If this problem happens, modify the wire connection, repair or replace the plug or socket.
  3. How To Repair A Solenoid Coil, Problem with the valve element: step 3, image 1 of 1
    • The valve element can be problematic because of too much water in the compressed air or too many foreign particles in the liquid medium.
    • Check the valve element and get rid of all the foreign matters.
    • If problem still occurs, replace the full valve element.
  4. How To Repair A Solenoid Coil, Solenoid valve won't work after turned on: step 4, image 1 of 1
    • bad wiring. Re-connect the wire.
    • Regulate voltage to the normal range.
    • weld the solenoid coil again.
    • regulate the pressure differences.
  5. How To Repair A Solenoid Coil, The solenoid valve cannot close: step 5, image 1 of 1
    • replace the sealing parts of broken valve element
    • replace the solenoid valve with a suitable one for medium with a higher temperature.
    • clean the foreign matters in the valve element.
Jack Huang
198 Reputation
1 Guide authored
One Comment
You can visit this website to learn more about hydraulic solenoid.
Jack Huang - Reply
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 85
All Time: 12,815
