How To Replace A Subaru Outback Exhaust Front Cover
  1. How To Replace A  Subaru Outback Exhaust Front Cover, Exhaust Front Cover: step 1, image 1 of 1
    • Collect Supplies.
    • Make sure the new Exhaust Front Cover is free of stickers, oil, or residues.
  2. How To Replace A  Subaru Outback Exhaust Front Cover: step 2, image 1 of 1
    • Park Outback on a level dry and clean surface.
    • Make sure that the car is in park for an automatic transmission or in first gear for a manual transmission. Verify that the parking brake is engaged.
  3. How To Replace A  Subaru Outback Exhaust Front Cover: step 3, image 1 of 1
    • Put on safety glasses. Be sure to leave them on until the fix is complete.
    • Do not touch any exhaust components until you have verified that there is no danger of getting burned.
    • Laying on your back, maneuver yourself underneath the driver or passenger side of the car carrying the 12mm combination wrench. Locate yourself about even with the back of the front door.
  4. How To Replace A  Subaru Outback Exhaust Front Cover: step 4, image 1 of 3 How To Replace A  Subaru Outback Exhaust Front Cover: step 4, image 2 of 3 How To Replace A  Subaru Outback Exhaust Front Cover: step 4, image 3 of 3
    • Unplug the rear oxygen sensor connector and carefully route the wires through the Exhaust Front Cover so they are no longer passing through it.
  5. How To Replace A  Subaru Outback Exhaust Front Cover: step 5, image 1 of 3 How To Replace A  Subaru Outback Exhaust Front Cover: step 5, image 2 of 3 How To Replace A  Subaru Outback Exhaust Front Cover: step 5, image 3 of 3
    • Locate the four mounting bolts for the Exhaust Front Cover.
    • Remove the bolts by turning them counterclockwise using the 12mm combination wrench.
  6. How To Replace A  Subaru Outback Exhaust Front Cover: step 6, image 1 of 1
    • Remove the old Exhaust Front Cover taking care to prevent damage to the vehicles undercoating and the oxygen sensor wires.
To reassemble your exhaust front cover, follow these instructions in reverse order.
redacted
101 Reputation
1 Guide authored
Cal Poly, Team 23-1, Green Winter 2015 Member of Cal Poly, Team 23-1, Green Winter 2015
CPSU-GREEN-W15S23G1
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 797
