How to Bind Transmitter and Reciever
    • Disconnect the power cable and remove the battery
    • If using a transmitter other than the Blade MLP4DSM, add a new model to the transmitter.
    • Select the appropriate model type.
    • Center all trims on the transmitter.
    • If using the Blade MLP4DSM, press the trim buttons until you hear a long low beep (roll and pitch trim) or three short low beeps (throttle and yaw trim). This indicates that the trim is centered.
    • Turn the power off on the transmitter.
    • Make sure the throttle is in the off position.
    • If using a transmitter other than the Blade MLP4DSM, make sure that all switches are in the 0 position.
    • Reconnect the power cable to the battery.
    • Make sure not to bend the pins on the connector.
    • After 5 seconds, the status LED will turn blue and begin flashing rapidly, indicating that it has entered bind mode.
    • Put the transmitter into bind mode while powering it on.
    • If using the Blade MLP4DSM, push and hold the left stick while powering on the transmitter. Release the left stick. You will hear a beep and the power LED will blink.
    • If using a different transmitter, consult the manual on how to enter bind mode.
    • The status LED will turn solid blue when it is successfully bound to the transmitter.
    • Disconnect the battery from the power cable.
    • Power off the transmitter.
You should now be ready to fly your quadcopter.
2 other people completed this guide.
Ian Glen
651 Reputation
3 Guides authored
2 Guide Comments
That worked perfectly for me! And I used the MLP6 transmitter. Thanks kid! ;)
jamiekif - Reply
The drone is bound now but I cant get it to arm. Any suggestions? Not sure how to do it on this controller. Thank you!
rob_swain - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 39
All Time: 6,007
