How to Change Mercedes W123 Power Steering Fluid and Filter
  1. How to Change Mercedes W123 Power Steering Fluid and Filter, How to Change Mercedes W123 Power Steering Fluid and Filter: step 1, image 1 of 1
  2. How to Change Mercedes W123 Power Steering Fluid and Filter: step 2, image 1 of 3 How to Change Mercedes W123 Power Steering Fluid and Filter: step 2, image 2 of 3 How to Change Mercedes W123 Power Steering Fluid and Filter: step 2, image 3 of 3
  3. How to Change Mercedes W123 Power Steering Fluid and Filter: step 3, image 1 of 1
    • With the lid removed you can see that this fluid is a bit low, and is also very dark/dirty.
  4. How to Change Mercedes W123 Power Steering Fluid and Filter: step 4, image 1 of 2 How to Change Mercedes W123 Power Steering Fluid and Filter: step 4, image 2 of 2
    • Remove the nut holding down the spring and plastic retainer, if present. On some cars, there is just a spring as shown in the second picture which should be removed.
    • The nut on this car is a 10mm.
  5. How to Change Mercedes W123 Power Steering Fluid and Filter: step 5, image 1 of 1
    • Now use your fluid extractor, or turkey baster (never use it in the kitchen again!) to remove enough fluid to get easy access to the filter.
    • Dispose of the fluid in your drain pan.
  6. How to Change Mercedes W123 Power Steering Fluid and Filter: step 6, image 1 of 1
    • Remove the filter using a pair of needle nose pliers.
  7. How to Change Mercedes W123 Power Steering Fluid and Filter: step 7, image 1 of 3 How to Change Mercedes W123 Power Steering Fluid and Filter: step 7, image 2 of 3 How to Change Mercedes W123 Power Steering Fluid and Filter: step 7, image 3 of 3
    • See how nasty this is? This may be the original filter, almost 30 years old...
    • Nice fresh filter picture, ready for install.
  8. How to Change Mercedes W123 Power Steering Fluid and Filter: step 8, image 1 of 1
    • With the filter out, you can remove the remainder of the fluid in the reservoir.
  9. How to Change Mercedes W123 Power Steering Fluid and Filter: step 9, image 1 of 1
    • Install your new filter. Install it with the holes facing upwards, as shown.
  10. How to Change Mercedes W123 Power Steering Fluid and Filter: step 10, image 1 of 1
    • Replace the spring, retainer and nut over the filter and tighten down. The spring should still have some room to expand and contract but should be snug.
    • Fill the reservoir to the bottom of the metal rim around the top of the pump housing.
    • This car is getting power steering fluid, instead of automatic transmission fluid. Both are OK. The power steering fluid is clear.
    • Now, turn on the engine. Be sure the car is in park or neutral first. Turn the steering wheel left and right, as far as it will go, a few times to get out any air.
    • Top off the fluid as needed. Never let the pump run dry.
    • If your fluid is very dirty, simply repeat the process of sucking out fluid, putting the filter back in, filling the reservoir, and then running the engine and turning the wheel until it looks clean.
Finish by re-installing the cap and taking it for a test drive.
21 other people completed this guide.
Nicolas Siemsen
39,284 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
14 Comments
I find this tutorial so simple to follow. I prefer images and text to video. Well done!!!
Holden Belmont - Reply
Holden, I am glad it was helpful! I agree, I usually prefer good pictures and text to a video - no need to rewind when you miss something.
Nicolas Siemsen -
Agreed. Very well done !
susan vernon - Reply
Thank you so much for your detailed guides! What sort of symptoms could we expect if the power steering fluid or filter need replacing?
Angel Jon Camama - Reply
This was so professional; technical writers take notice!
Brian Graham - Reply
Past 24 Hours: 4
Past 7 Days: 47
Past 30 Days: 140
All Time: 25,197
