How to Clean a Dirt Devil Vacuum Cleaner Roller Brush
  1. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush, How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: step 1, image 1 of 1
    • Lay the vacuum cleaner on the floor so that the bottom of the vacuum is facing upwards.
  2. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: step 2, image 1 of 1
    • Use a Phillips head screwdriver to remove eight screws.
  3. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: step 3, image 1 of 1
    • Disassemble the vacuum head and pop out your roller brush.
  4. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: step 4, image 1 of 1
    • Cut the ends with scissors.
    • Cover the floor with papers to prevent debris and hair from falling on the ground.
  5. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: step 5, image 1 of 1
    • Use a brush to clean the roller brush.
  6. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: step 6, image 1 of 2 How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: step 6, image 2 of 2
    • Put the rectangular part on both sides.
  7. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: step 7, image 1 of 2 How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: step 7, image 2 of 2
    • Check if the belt is attached.
    • Check if the motor part is well inserted with the belt attached to the roller brush.
    • Make sure the shape of the motor fits to prevent it from falling.
  8. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: step 8, image 1 of 1
    • Use your Phillips head screwdriver to screw in all eight of the screws.
Finish Line
4 Comments
Might be helpful if you showed where all 8 screws are seeing how I can only find 6 and cannot get it open!
Crystal - Reply
in the front there are to wheels, pop them out and you will see the other 2 screws
Mario Lore -
my power express lite only has 6 screws as well. I cannot get it open, I'm afraid it will break if I keep prying.
Gregory Penniston - Reply
Can I hand wash the brushes and rollers.
Lynne - Reply
Past 24 Hours: 10
Past 7 Days: 52
Past 30 Days: 204
All Time: 8,303
