How to Clean a Mainstays Coffee Maker Water Tube
  1. How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: step 1, image 1 of 3 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: step 1, image 2 of 3 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: step 1, image 3 of 3
    • Open the top of the coffee maker.
  2. How to Clean a Mainstays Coffee Maker Water Tube: step 2, image 1 of 2 How to Clean a Mainstays Coffee Maker Water Tube: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the four 6 mm screws surrounding the puncturing needle.
  3. How to Clean a Mainstays Coffee Maker Water Tube: step 3, image 1 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 3, image 2 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 3, image 3 of 3
    • Press down on the brew chamber release button and remove the backing piece.
  4. How to Clean a Mainstays Coffee Maker Water Tube: step 4, image 1 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 4, image 2 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 4, image 3 of 3
    • Disconnect the water tube from where it is connected to the needle.
  5. How to Clean a Mainstays Coffee Maker Water Tube: step 5, image 1 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 5, image 2 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 5, image 3 of 3
    • Flip the coffee maker upside down.
  6. How to Clean a Mainstays Coffee Maker Water Tube: step 6, image 1 of 2 How to Clean a Mainstays Coffee Maker Water Tube: step 6, image 2 of 2
    • Use a Phillips screwdriver to remove the four 7 mm screws on the base of the coffee maker.
  7. How to Clean a Mainstays Coffee Maker Water Tube: step 7, image 1 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 7, image 2 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 7, image 3 of 3
    • Remove the base.
  8. How to Clean a Mainstays Coffee Maker Water Tube: step 8, image 1 of 2 How to Clean a Mainstays Coffee Maker Water Tube: step 8, image 2 of 2
    • Use an 8" Phillips screwdriver to remove the five internal 14 mm screws from within the coffee maker.
    • Use an 8" Phillips screwdriver to remove the six internal 7 mm screws from within the coffee maker.
    • The second image shows the approximate placement of the screws; you may have to reach inside and move wires to locate and access all eleven screws.
  9. How to Clean a Mainstays Coffee Maker Water Tube: step 9, image 1 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 9, image 2 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 9, image 3 of 3
    • Flip the coffee maker right-side up.
  10. How to Clean a Mainstays Coffee Maker Water Tube: step 10, image 1 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 10, image 2 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 10, image 3 of 3
    • Pull the disconnected end of the water tube out of the top of the coffee maker.
  11. How to Clean a Mainstays Coffee Maker Water Tube: step 11, image 1 of 1
    • Move the top of the coffee maker out of the way so that you can reach into the base.
    • You may wish to put something under the top to support it.
  12. How to Clean a Mainstays Coffee Maker Water Tube: step 12, image 1 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 12, image 2 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 12, image 3 of 3
    • Identify where the water tube is connected at the other end.
    • Use pliers or your hand to disconnect it.
    • If you choose to use pliers, take caution not to puncture the tube.
  13. How to Clean a Mainstays Coffee Maker Water Tube: step 13, image 1 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 13, image 2 of 3 How to Clean a Mainstays Coffee Maker Water Tube: step 13, image 3 of 3
    • Locate any blockages in the water tube and use your chosen tool (chenille stick, wooden dowel, toothpick, etc.) to push them out.
    • If the tube looks cloudy, use a chenille stick to break up the buildup.
  14. How to Clean a Mainstays Coffee Maker Water Tube: step 14, image 1 of 1
    • Rinse any remaining debris out of the tube.
    • Depending on what tool you chose to use in the previous step, particles from said tool may need to be rinsed out as well.
Lorelei Kriss
229 Reputation
1 Guide authored
UC Davis, Team 4-9, Andersen Winter 2024 Member of UC Davis, Team 4-9, Andersen Winter 2024
UCD-ANDERSEN-W24S4G9
2 Members
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 28
All Time: 207
