How to Clean an Electric Valve for Air Horns
  1. How to Clean an Electric Valve for Air Horns, Rotate the valve to have easier access: step 1, image 1 of 2 How to Clean an Electric Valve for Air Horns, Rotate the valve to have easier access: step 1, image 2 of 2
    • Use the socket wrench to rotate the valve.
  2. How to Clean an Electric Valve for Air Horns, Unscrew the fixing nut: step 2, image 1 of 3 How to Clean an Electric Valve for Air Horns, Unscrew the fixing nut: step 2, image 2 of 3 How to Clean an Electric Valve for Air Horns, Unscrew the fixing nut: step 2, image 3 of 3
    • Unscrew the fixing nut using the wrench.
    • Don't lose the pieces: put them in order in a safe place. A good example is a white sheet of paper.
  3. How to Clean an Electric Valve for Air Horns, Unscrew the head of the valve: step 3, image 1 of 3 How to Clean an Electric Valve for Air Horns, Unscrew the head of the valve: step 3, image 2 of 3 How to Clean an Electric Valve for Air Horns, Unscrew the head of the valve: step 3, image 3 of 3
    • Remove the solenoid (the black plastic box).
    • Carefully unscrew the head of the valve: it could be hard to remove due to the threadlocker.
    • Use the Rib Jonit plier and apply a counterclockwise rotation on it.
    • Finish the unscrewing by hand.
    • Don't lose the head: put it, again, in a safe place.
  4. How to Clean an Electric Valve for Air Horns, Remove piston and spring: step 4, image 1 of 2 How to Clean an Electric Valve for Air Horns, Remove piston and spring: step 4, image 2 of 2
    • Gently tilt the whole thing and the spring and piston should exit the valve.
    • Inspect them for cleanliness and put them in a safe place.
  5. How to Clean an Electric Valve for Air Horns, Use compressed air to clean the valve: step 5, image 1 of 2 How to Clean an Electric Valve for Air Horns, Use compressed air to clean the valve: step 5, image 2 of 2
    • Blow in the valve with compressed air to clean it
    • Blow on the piston and other pieces, if dirty, as well.
  6. How to Clean an Electric Valve for Air Horns, Reassemble the valve: step 6, image 1 of 2 How to Clean an Electric Valve for Air Horns, Reassemble the valve: step 6, image 2 of 2
    • Place the piston, first.
    • Then put the spring in the piston's hole.
  7. How to Clean an Electric Valve for Air Horns, Insert the head of the valve: step 7, image 1 of 3 How to Clean an Electric Valve for Air Horns, Insert the head of the valve: step 7, image 2 of 3 How to Clean an Electric Valve for Air Horns, Insert the head of the valve: step 7, image 3 of 3
    • Put some threadlocker on the thread
    • Don't exceed: you may permanently damage the device!
    • Screw the head on the valve.
    • Use the plier to tighten valve's head: there's no need to tighten it too much.
  8. How to Clean an Electric Valve for Air Horns, Finish the job: step 8, image 1 of 3 How to Clean an Electric Valve for Air Horns, Finish the job: step 8, image 2 of 3 How to Clean an Electric Valve for Air Horns, Finish the job: step 8, image 3 of 3
    • Insert the solenoid and put the washer on the top.
    • Finally, screw the nut with the wrench.
    • Set the valve back in place, using the wrench.
Keep your valves checked, if you want them to last longer!
5 other people completed this guide.
Marco Spa
1,501 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 28
All Time: 3,277
