How to Clean the InFocus X2 Lamp Housing Screens
Paulina Duarte
Paulina Duarte and one other contributor
Last updated on January 14, 2020
5 minutes
Easy
Community-Contributed Guide
iFixit earns commission when you buy through these links.
  1. How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: step 1, image 1 of 3 How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: step 1, image 2 of 3 How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: step 1, image 3 of 3
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: step 2, image 1 of 3 How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: step 2, image 2 of 3 How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: step 2, image 3 of 3
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: step 3, image 1 of 3 How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: step 3, image 2 of 3 How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: step 3, image 3 of 3
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. How to Clean the InFocus X2 Lamp Housing Screens, Remove the Old Lamp: step 4, image 1 of 1
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. How to Clean the InFocus X2 Lamp Housing Screens, Insert the New Lamp: step 5, image 1 of 1
    • Insert the replacement lamp into the projector.
  6. How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: step 6, image 1 of 2 How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: step 6, image 2 of 2
    • Use a vacuum cleaner to gently suck up the dust on the front and the back Lamp Housing screens.
Attached Documents
Paulina Duarte
553 Reputation
4 Guides authored
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G3
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 183
