How to Create a Guide
  1. How to Create a Guide, Open User Menu: step 1, image 1 of 1
    • Click on your username in the top right corner of the site.
    • Select Create A Page from the drop-down menu.
    • If you are already on the category page in which you intend to organize your new guide, you can simply click the Create a Guide button at the top of the page.
  2. How to Create a Guide, Start a New Guide Page: step 2, image 1 of 3 How to Create a Guide, Start a New Guide Page: step 2, image 2 of 3 How to Create a Guide, Start a New Guide Page: step 2, image 3 of 3
    • Select Guide from the Page Options list.
    • Enter the name of the category you'd like to organize your new guide within.
    • If the category already exists, it will appear in a drop-down list below the text box. Select the your category from the list.
    • If the category does not already exist, a new category page will be created.
    • Click Next.
  3. How to Create a Guide, Add Introduction Content: step 3, image 1 of 1
    • Enter a Title for your new guide.
    • Add a summary to briefly explain what the guide will demonstrate.
    • If you would like to add other information at this time, such as an introduction or flags, click See More.
    • Review the Parts of a Guide Page to better understand the various elements that make up a guide.
    • When finished adding information, click Save.
  4. How to Create a Guide, Create a Step: step 4, image 1 of 3 How to Create a Guide, Create a Step: step 4, image 2 of 3 How to Create a Guide, Create a Step: step 4, image 3 of 3
    • Begin creating the body of your guide by creating your first guide step.
    • Click on the Add a Title text to enter a title for your first step.
    • Click on the Insert wisdom here text to enter your first bullet point text instructions.
    • Use the formatting toolbar at the top of the text editing box to format your text or add links.
    • Use the arrows below the text box indent your bullet. Use the + icon to create a new bullet and the X icon to delete the bullet.
    • Click on the bullet icon itself to change the color or icon for the bullet.
    • Select from the color/icon menu to change your bullet point.
    • Click Save to create your first step!
  5. How to Create a Guide, Keyboard Shortcuts: step 5, image 1 of 2 How to Create a Guide, Keyboard Shortcuts: step 5, image 2 of 2
    • Click the keyboard icon at the top of the guide to open a Keyboard Shortcuts pop-up window.
    • Use these (and others listed in the KeyBoard Shortcuts window) to quickly navigate while creating guide steps:
    • Return: Next bullet or insert new bullet.
    • Shift + Return: Previous Bullet or Insert Bullet Above
    • Ctrl + ]: Indent bullet.
    • Ctrl + [: Unindent bullet.
    • Ctrl + D: Delete bullet.
  6. How to Create a Guide, Add Step Visuals: step 6, image 1 of 3 How to Create a Guide, Add Step Visuals: step 6, image 2 of 3 How to Create a Guide, Add Step Visuals: step 6, image 3 of 3
    • Select from either Image or Media to add to your step below the step title.
    • You can add up to three images per step, while video and other media is limited to one file per step.
    • Click the image or media placeholder to open your Media Manager.
    • Click the Add Media button to add a new image or video to your library. Review the Media Manager Help Page for more information about using media.
    • Select the image or media 'file from your library by clicking on it. This will add it to your guide step.
    • If you are using images, you can use the two remaining image placeholders to add up to three images to your step.
    • Click Save to save your visual guide step.
  7. How to Create a Guide, Add Image Markup: step 7, image 1 of 3 How to Create a Guide, Add Image Markup: step 7, image 2 of 3 How to Create a Guide, Add Image Markup: step 7, image 3 of 3
    • Note: Markup cannot be added to videos or other media.
    • Move your curser over your new guide step image, then click the Edit button in the bottom right corner.
    • Select the Markers option from the menu that appears to open the Markup Window.
    • Use the Tool menu at the top left to select a shape, line or arrow marker, then simply click the image where you'd like to add the marker and adjust the size, shape and orientation as needed.
    • Use the Color menu at the top right to select a color for your new marker.
    • Once you've created all desired markers, click the Save Changes button in the very top right corner of the Markup Window.
    • View your new image with the markup and click Save to save it to your guide step.
  8. How to Create a Guide, Add More Steps: step 8, image 1 of 1
    • Click the + icon in the Step section at the top right corner of the page to add a new step. This option will always add the new step to the end of the guide.
    • You can also use the + Insert Step button to add a new step immediately after the step you're currently editing, rather than at the end of the guide.
  9. How to Create a Guide, Guide Details & Settings: step 9, image 1 of 1
2 other people completed this guide.
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 21
All Time: 1,098
