How to Decrease the Bicep of a Sleeve
  1. How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: step 1, image 1 of 3 How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: step 1, image 2 of 3 How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: step 1, image 3 of 3
    • Flip your shirt inside out.
    • The raw edges should be on the outside.
  2. How to Decrease the Bicep of a Sleeve: step 2, image 1 of 3 How to Decrease the Bicep of a Sleeve: step 2, image 2 of 3 How to Decrease the Bicep of a Sleeve: step 2, image 3 of 3
    • Use a measuring tape to measure your desired width from the top point of the shoulder down to the seam of the shoulder.
    • Mark the bottom point of your measurement with a fabric pen or tailor's chalk.
  3. How to Decrease the Bicep of a Sleeve: step 3, image 1 of 3 How to Decrease the Bicep of a Sleeve: step 3, image 2 of 3 How to Decrease the Bicep of a Sleeve: step 3, image 3 of 3
    • Use a fabric marker or tailor's chalk to draw a line from the marking, ensuring it aligns with the rest of the sleeve.
    • It should align with the sleeve at the cuff.
    • Draw another line from the marking, extending down to align with the side of the body of the shirt.
  4. How to Decrease the Bicep of a Sleeve: step 4, image 1 of 3 How to Decrease the Bicep of a Sleeve: step 4, image 2 of 3 How to Decrease the Bicep of a Sleeve: step 4, image 3 of 3
    • Use straight pins to pin the sleeve across the lines you drew.
    • Push the pin through the top and push it back through the bottom of the sleeve.
    • Place a pin every inch across the lines.
  5. How to Decrease the Bicep of a Sleeve: step 5, image 1 of 3 How to Decrease the Bicep of a Sleeve: step 5, image 2 of 3 How to Decrease the Bicep of a Sleeve: step 5, image 3 of 3
    • Using a sewing machine, sew across the pinned lines with a straight stitch.
    • Be sure to backstitch at the start and end of your stitch.
  6. How to Decrease the Bicep of a Sleeve: step 6, image 1 of 3 How to Decrease the Bicep of a Sleeve: step 6, image 2 of 3 How to Decrease the Bicep of a Sleeve: step 6, image 3 of 3
    • Use scissors to cut off the excess fabric.
    • Leave a seam allowance of 6.4 mm.
  7. How to Decrease the Bicep of a Sleeve: step 7, image 1 of 1
    • Measure again to see if you reached your desired width.
Now that you have finished your fix, go ahead and try on that perfect-fitting shirt. Thank you for picking this fast fix guide!
Elliot T
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 140
