How to Descale a Breville Barista Pro BES878-RVC
  1. How to Descale a Breville Barista Pro BES878-RVC, How to Descale a Breville Barista Pro BES878-RVC: step 1, image 1 of 1
    • Press the power button to power on the espresso machine.
  2. How to Descale a Breville Barista Pro BES878-RVC: step 2, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 2, image 2 of 2
    • Pull out and empty the water tank and drip tray.
  3. How to Descale a Breville Barista Pro BES878-RVC: step 3, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 3, image 2 of 2
    • Pull out the water filter from the water tank.
  4. How to Descale a Breville Barista Pro BES878-RVC: step 4, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 4, image 2 of 2
    • Pour a packet of descaler (or a descaler tablet) into the water tank.
    • Fill the water tank with fresh water to the descale line located on the side of the water tank.
    • If you do not have a descaler, pour a 1:1 mixture of white vinegar and water into the water tank instead.
  5. How to Descale a Breville Barista Pro BES878-RVC: step 5, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 5, image 2 of 2
    • Reinsert water tank and drip tray.
  6. How to Descale a Breville Barista Pro BES878-RVC: step 6, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 6, image 2 of 2
    • Position the steam wand above the drip tray.
    • If you wish to prevent splashing, place a tall bowl or cup under the steam wand.
  7. How to Descale a Breville Barista Pro BES878-RVC: step 7, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 7, image 2 of 2
    • Press the menu button.
    • Turn the knob labelled “Filter Size” counterclockwise until the “descale” label is blinking on the display.
  8. How to Descale a Breville Barista Pro BES878-RVC: step 8, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 8, image 2 of 2
    • Press down on the “Filter Size” knob to select descale.
    • The letter d will appear on the display and the one cup button will illuminate.
  9. How to Descale a Breville Barista Pro BES878-RVC: step 9, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 9, image 2 of 2
    • Press the one cup button to enter descale mode.
    • d3 will appear on the display and water will pour from the group head.
  10. How to Descale a Breville Barista Pro BES878-RVC: step 10, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 10, image 2 of 2
    • Wait for the display to show “d2.”
    • Rotate the right dial to the hot water icon to descale the hot water dispenser.
  11. How to Descale a Breville Barista Pro BES878-RVC: step 11, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 11, image 2 of 2
    • Wait for the display to show “d1.”
    • Rotate the right dial to the steam icon to descale the steam wand.
  12. How to Descale a Breville Barista Pro BES878-RVC: step 12, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 12, image 2 of 2
    • Wait for the display to show “r.”
    • Rotate the right dial back to the neutral position.
    • r means "rinse." You are now in the rinsing phase of descaling your espresso machine.
  13. How to Descale a Breville Barista Pro BES878-RVC: step 13, image 1 of 3 How to Descale a Breville Barista Pro BES878-RVC: step 13, image 2 of 3 How to Descale a Breville Barista Pro BES878-RVC: step 13, image 3 of 3
    • Pull out and empty the water tank.
    • Fill the water tank with fresh water to the max line.
    • Reinsert the water tank.
  14. How to Descale a Breville Barista Pro BES878-RVC: step 14, image 1 of 3 How to Descale a Breville Barista Pro BES878-RVC: step 14, image 2 of 3 How to Descale a Breville Barista Pro BES878-RVC: step 14, image 3 of 3
    • Pull out the drip tray.
    • Empty the drip tray.
    • Reinsert the drip tray.
  15. How to Descale a Breville Barista Pro BES878-RVC: step 15, image 1 of 3 How to Descale a Breville Barista Pro BES878-RVC: step 15, image 2 of 3 How to Descale a Breville Barista Pro BES878-RVC: step 15, image 3 of 3
    • Press the one cup button to initiate the rinse cycle.
    • “r3” should appear on the display.
    • Wait for the display to show “r2”.
    • Rotate the right dial to the hot water icon to rinse the hot water dispenser.
  16. How to Descale a Breville Barista Pro BES878-RVC: step 16, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 16, image 2 of 2
    • Wait for the display to show “r1.”
    • Rotate the right dial to the steam icon to rinse the steam wand.
  17. How to Descale a Breville Barista Pro BES878-RVC: step 17, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 17, image 2 of 2
    • Once the rinse is complete, the grind amount option will appear on the display.
  18. How to Descale a Breville Barista Pro BES878-RVC: step 18, image 1 of 3 How to Descale a Breville Barista Pro BES878-RVC: step 18, image 2 of 3 How to Descale a Breville Barista Pro BES878-RVC: step 18, image 3 of 3
    • Pull out the water tank.
    • Reinsert the water filter.
    • Refill the water tank with fresh water.
  19. How to Descale a Breville Barista Pro BES878-RVC: step 19, image 1 of 1
    • Pull out and empty the drip tray.
  20. How to Descale a Breville Barista Pro BES878-RVC: step 20, image 1 of 2 How to Descale a Breville Barista Pro BES878-RVC: step 20, image 2 of 2
    • Reinsert the water tank and drip tray.
    • Your expresso machine should be clean and produce better tasting drinks!
Finish Line
Jeffery Huang
301 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 76
Past 30 Days: 282
All Time: 1,434
