How to Descale a Nespresso VertuoPlus
Olivia peet
Olivia peet and 3 other contributors
Last updated on February 26, 2024
20 minutes
Very easy
Introduction
Go to step 1
Are you wondering why your Nespresso coffee is tasting off and doesn’t have that sufficient taste? Use this guide to learn how to descale your Nespresso VertuoPlus machine in an easy few steps.
Descaling your coffee machine is ultimately cleaning and stripping any excess dirt that has built up on the machine’s surface which could potentially cause your coffee machine to stop functioning properly and result in bad-tasting coffee.
Before using this guide, make sure you have the Nespresso descaling kit. Any other type of cleaning solution used in the machine could potentially break the machine.
iFixit earns commission when you buy through these links.
  1. How to Descale a Nespresso VertuoPlus, How to Descale a Nespresso VertuoPlus: step 1, image 1 of 1
    • Turn the machine on by pressing the button with a coffee mug logo.
  2. How to Descale a Nespresso VertuoPlus: step 2, image 1 of 3 How to Descale a Nespresso VertuoPlus: step 2, image 2 of 3 How to Descale a Nespresso VertuoPlus: step 2, image 3 of 3
    • Lift the lever upwards to remove any used capsules from the machine.
    • Empty the capsule container that is located at the back of the machine.
  3. How to Descale a Nespresso VertuoPlus: step 3, image 1 of 1
    • Turn the machine off by pushing the same lever down.
  4. How to Descale a Nespresso VertuoPlus: step 4, image 1 of 1
    • Fill the water tank with one unit of the Nespresso descaling liquid and add three cups of water to the solution.
  5. How to Descale a Nespresso VertuoPlus: step 5, image 1 of 1
    • To access the descaling mode on the machine, push both the button and lever down for three seconds.
    • You will see an orange light, indicating that you have reached the "Special Functions" menu.
  6. How to Descale a Nespresso VertuoPlus: step 6, image 1 of 1
    • To access the descaling mode, press the lever down one time.
  7. How to Descale a Nespresso VertuoPlus: step 7, image 1 of 1
    • To start descaling, push the button.
    • An orange light will start to blink indicating the descaling function.
    • The machine will stop automatically when completed.
  8. How to Descale a Nespresso VertuoPlus: step 8, image 1 of 1
    • Empty the descaling liquid from the water tank.
    • Rinse and clean the tank thoroughly.
  9. How to Descale a Nespresso VertuoPlus: step 9, image 1 of 1
    • Fill the water tank with fresh water and place it back into the machine.
  10. How to Descale a Nespresso VertuoPlus: step 10, image 1 of 1
    • Push the button to rinse the machine.
  11. How to Descale a Nespresso VertuoPlus: step 11, image 1 of 1
    • To exit descaling mode, press both the button and lever at the same time for three seconds.
  12. How to Descale a Nespresso VertuoPlus: step 12, image 1 of 1
    • A green light will show, indicating the descaling has been completed successfully.
Finish Line
43 other people completed this guide.
Olivia peet
1,237 Reputation
1 Guide authored
12 Guide Comments
When I hit the button to begin the descaling process, the orange light flashes for a few seconds then I get a red ring and the machine stops
James Spavelko - Reply
I usually require six envelopes to descale (six times). We have very hard water where we live. Keep repeating process. Once machine has descaled enough, it will go back to green. Persistence wins.
Laura Retana -
perchè pur funzionante si accende la spia circolare di colore per metà rossa e metà verde?
Attilio Carioti - Reply
Devi fare la decalcificazione ti da ancora la possibilità di usarla ma per un breve periodo
Luca Levra -
Perché dopo aver fatto la decalcificazione compare ancora la spia metà rossa e metà verde?
maria.padovano1 - Reply
Past 24 Hours: 34
Past 7 Days: 333
Past 30 Days: 1,677
All Time: 205,191
