How to Dewalt Rotary Drill D25104 type 2
  1. How to Dewalt Rotary Drill D25104 type 2, checking power: step 1, image 1 of 2 How to Dewalt Rotary Drill D25104 type 2, checking power: step 1, image 2 of 2
    • first of all we will check the power.
    • plug your drill into a power outlet and try it.
    • If the machine wants to start but immediately shuts down , there is a chance the brushes needs to be replaced.
    • If no power comes up ( like mine) you have to check the power cord first
  2. How to Dewalt Rotary Drill D25104 type 2, removing plastic handframe: step 2, image 1 of 3 How to Dewalt Rotary Drill D25104 type 2, removing plastic handframe: step 2, image 2 of 3 How to Dewalt Rotary Drill D25104 type 2, removing plastic handframe: step 2, image 3 of 3
    • remove the 2 flathead/ torx screws holding the plastic frame at the bottom.
    • remove the flathead/torx screw at the upper side of the frame.
    • slide the frame to the right.
  3. How to Dewalt Rotary Drill D25104 type 2, checking power cord: step 3, image 1 of 2 How to Dewalt Rotary Drill D25104 type 2, checking power cord: step 3, image 2 of 2
    • check the brown and blue wire with a multimeter.
    • put the red probe from the multimeter on the brown cable and ( copper head)and the black probe of the multimeter on the blue wire ( copper head)
    • if you measure 230 V it should be ok ( in Europe it is 230 V.. i think in the US it would be 110V ...)
    • be sure you put the multimeter in AC V mode and not in DC.
  4. How to Dewalt Rotary Drill D25104 type 2, removing power cable.: step 4, image 1 of 3 How to Dewalt Rotary Drill D25104 type 2, removing power cable.: step 4, image 2 of 3 How to Dewalt Rotary Drill D25104 type 2, removing power cable.: step 4, image 3 of 3
    • Remove power cable by removing the 2 flathead/torx screws.
    • be gently and careful with the condensator. ( yellow "briwk" with the 2 black small wires.
  5. How to Dewalt Rotary Drill D25104 type 2, remove cable: step 5, image 1 of 2 How to Dewalt Rotary Drill D25104 type 2, remove cable: step 5, image 2 of 2
    • remove the 2 small screws holding the brown and blue powerwires.
  6. How to Dewalt Rotary Drill D25104 type 2: step 6, image 1 of 1
    • check fot bad connections. ( in this case you will see one bad connection from the condensator )
  7. How to Dewalt Rotary Drill D25104 type 2: step 7, image 1 of 2 How to Dewalt Rotary Drill D25104 type 2: step 7, image 2 of 2
    • pull out the switch to check the connections and measure out the switch.
    • how more powerfull the motor , the more likely a bad switch is.
    • when reasemble the switch/machine : under the switch there is a plastic pin , that has to fit in a gap from the "forward, reverse) switch
  8. How to Dewalt Rotary Drill D25104 type 2, checking and renewing brushes: step 8, image 1 of 3 How to Dewalt Rotary Drill D25104 type 2, checking and renewing brushes: step 8, image 2 of 3 How to Dewalt Rotary Drill D25104 type 2, checking and renewing brushes: step 8, image 3 of 3
    • remove the 2 swal torx (t9) screws , holding the brush head.
  9. How to Dewalt Rotary Drill D25104 type 2, checking and renewing brushes: step 9, image 1 of 1
    • when replacing : push the brush in the head ; click the wire on the right place and put it back. sometimes you will need to push the brush in place.
  10. How to Dewalt Rotary Drill D25104 type 2, checking and renewing brush 2nd: step 10, image 1 of 3 How to Dewalt Rotary Drill D25104 type 2, checking and renewing brush 2nd: step 10, image 2 of 3 How to Dewalt Rotary Drill D25104 type 2, checking and renewing brush 2nd: step 10, image 3 of 3
    • remove 1 torx ('t9) screw to remove the brush head.
  11. How to Dewalt Rotary Drill D25104 type 2, detailed view: step 11, image 1 of 3 How to Dewalt Rotary Drill D25104 type 2, detailed view: step 11, image 2 of 3 How to Dewalt Rotary Drill D25104 type 2, detailed view: step 11, image 3 of 3
    • Insert wisdom here.
Kevin D
7,343 Reputation
21 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 62
All Time: 2,674
