How to Disconnect the Battery
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. How to Disconnect the Battery, Remove the battery board cover: step 1, image 1 of 2 How to Disconnect the Battery, Remove the battery board cover: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Use blunt nose tweezers or your fingers to peel and remove the cover from the battery board, just above the middle battery cell.
  2. How to Disconnect the Battery, Disconnect the battery data cable: step 2, image 1 of 2 How to Disconnect the Battery, Disconnect the battery data cable: step 2, image 2 of 2
    • Use blunt nose tweezers to gently peel back the pull tab covering the battery data connector.
    • Don't remove or tear the pull tab, as it's attached to the head of the connector.
  3. How to Disconnect the Battery: step 3, image 1 of 2 How to Disconnect the Battery: step 3, image 2 of 2
    • Use the point of a spudger to flip up the small locking tab securing the battery data connector.
    • Locking tabs on ZIF connectors are fragile—be gentle with your spudger.
  4. How to Disconnect the Battery: step 4, image 1 of 3 How to Disconnect the Battery: step 4, image 2 of 3 How to Disconnect the Battery: step 4, image 3 of 3
    • Use blunt nose tweezers or your fingers to grab the battery data cable pull tab and slide it straight out of its socket.
    • Move the cable to the left, out of the way of the battery board.
    • Don't strain the cable, as it's still attached to the battery board.
  5. How to Disconnect the Battery, Unfasten the battery connector: step 5, image 1 of 1
    • Use a T5 Torx driver to remove the 3.7 mm screw securing the battery connector.
  6. How to Disconnect the Battery, Disconnect the battery: step 6, image 1 of 3 How to Disconnect the Battery, Disconnect the battery: step 6, image 2 of 3 How to Disconnect the Battery, Disconnect the battery: step 6, image 3 of 3
    • Use the flat end of your spudger to slightly lift the battery connector away from the battery board.
    • Lifting the connector too high will break it. Angle it enough so it won't accidentally contact the battery board during repair.
    • Optionally, you may insert a barrier, such as a piece of a playing card, between the connector and the board during the repair.
Clay Eickemeyer
98,772 Reputation
471 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
16,327 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 105
