How to Disconnect the Display
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. How to Disconnect the Display, Remove the display cable bracket: step 1, image 1 of 2 How to Disconnect the Display, Remove the display cable bracket: step 1, image 2 of 2
    • Use a T3 Torx driver to remove the two 3.1 mm screws securing the display cable retaining bracket.
    • Remove the bracket.
  2. How to Disconnect the Display, Remove the display cable cover: step 2, image 1 of 2 How to Disconnect the Display, Remove the display cable cover: step 2, image 2 of 2
    • Use your T3 Torx driver to remove the two 1.7 mm screws securing the display cable cover.
    • Remove the cover.
  3. How to Disconnect the Display, Disconnect the display: step 3, image 1 of 2 How to Disconnect the Display, Disconnect the display: step 3, image 2 of 2
    • Use the flat end of your spudger to pry up and disconnect the display cable from the display board.
Clay Eickemeyer
97,000 Reputation
470 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
16,025 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 47
